1030L Massey Ferguson steering arm needed
ib4hoyt
New User
I have a 1030L 4 wheel drive ..the lower left side steering arm broke and i can't seem to find one anywhere! Any any all help on where i might find one will be greatly appreciated! Thanks
Will the mf65 standard steering arm work?
<image src="http://forums.yesterdaystractors.com/photos/mvphoto23851.jpg"/>
Hello,
Can't help you with an arm but the part number might help. If you are referring to the arm on the lhs that fits between the steering box and the rear end of the drag link; the number is 3439 132M1. As far as I can see from the AGCO parts book it appears that the same arm is fitted to 2 and 4wd and manual and power steering models.
DavidP, South Wales
The guy tool me it was called steering arm...its bolted to the bottom of the axle housing. .it has 3 bolt holes there and tapers down to about a 3/4" hole on other end. Wish i knew how to post pictures
Here is a picture of the broken one and the one on the other side to give and idea ....this is on the bottom.
Thanks...I've talked to dealers and can't get it...but
you are the first to give me a part number...I'll try
more with the number..thanks again
May have to try a tractor salvage yard. Toyosha the company that built that tractor was bought out by Hitachi in 1990. So finding the part maybe difficult. A good metal fabrication/machine shop should be able to make that arm.
The part number 3284306m1 seems to sub up to part number 72103895. Looks to be still available from Agco. Try this number at your Agco dealer. Sometimes parts men get a bit lazy and don't check further when a part number comes up "no longer available"
Wayne
