MF 360 Draw bar - where to find?
Great Oak
I can't believe how hard it is to find a draw bar for my tractor. seems like such a simple part. My MF 360 tractor has the setup for the draw bar. All I need if the draw bar and bolt or pin that secures it to tractor. Anyone know of any universal drawbars that will fit the MF360 and where to buy? For such a simple part its almost impossible to find where I am at.
More details- this center drawbar for this model made in Coventry, England is proving to be scarcer then hens teeth.
1. What tractor does the MF 360 most likely mirror in parts compatibility? I would think the 265-275 and 375 etc would be very similar in parts interchangeability.
2. Tractor currently has the Center draw bar base BUT missing the center draw bar. I need to find a center draw bar. Anyone find any universal parts for this that would fit and where did you find it?
3. Rsearched suppliers and there seems to be drawbars for 265/275 models Part numbers #531468M1 and #184611M1 seem like they should be standard for the mounting bracket. I can't see MF creating multiple mounting brackets or largely different dimensions for different model years
4. When I find a center draw bar how would this attach to the mounting bracket? when I dropped the bracket it appears there is a threaded spot for what might be for a mounting bolt for center draw bar and also another hole for maybe a mounting pin type setup.
Go to the agco web site, the parts book is free to use, seems there are two different drawbars for a 360
