Brendon Warren
I just bought a 165 with MP. The previous owner didn't use it so the linkage was stuck. I took the linkage off and am getting little play in just the rod down through the bellhousing. Its hard to tell if I'm moving the valve inside. On my 65s you could feel it. This one is kind of a bugger to get at. How much travel should be on that rod? Its stuck in low or high is out of it. Could any damage have been caused by leaving it in low so long? He said it worked but never used it because he wasn't familiar with it. He had it for 20+ years and only put 300 hrs on it. It also has square axles. Are these wet brakes? They sure work better than my 65 or 175. Thanks
