MW live PTO for Massey Harris 44
Texas CC
Does anyone have this setup installed on their tractor, all I know is when the lever is moved to the rear, output is disconnected to the transmission. This is installed behind the clutch housing.
I'd welcome any answers.
The first picture is from the right side of tractor, Second one from underneath. I suspect part of this is missing as dirt and grease should not be on gears like these.
Texas on the 44 that I ran they had an axle clutch the Lever disengaged it. Moline and others used a very similar set up. I suspect parts would be hard to get but the clutch and pressure plate could be rebuilt at a clutch shop. They worked real good for baling and such.
