Dopp Creek
My 65 diesel with power steering turns farther to the right than left. I hadn't noticed it til I was out baling and turning some tight corners. Hard to describe but I would say the fronts turn 30% less on the left. When the arm at the base of the steering pedestal is centered (halfway between full range of motion) and the front wheels straight, the drag link is the correct length. I tried making it longer or shorter with no noticeable change. With the drag link disconnected the arm at the base of the steering pedestal will swing aft (left turn direction) another inch. My manual doesn't offer much help so I'm turning to the brain trust for help. Any suggestions would be appreciated. Power steering functions the same in both directions, just can't get the range when turning left.
