will this work for MF-65 Manual to Power Steering
Rkh
found this used power steering & was wondering from you experts if this will work for my MF-65
Sure looks the same to me. the pump might be different if yours is a diesel though. These are pictures of the set up on my diesel 65.
Is there anything else needed to change from manual to power steering, tie rods, front axle, or some other part?
Don't have a clue about the 65's but the gear drive on the end of the pump must mesh with the gear inside of the timing cover.
headed out to pick up power steering unit the week of 1/13/2014 & will let you know how I made out. this is a great website for people like myself who dont have a lot of knowledge of these tractors. thanks for all your advices-this tractor forum is like the small tractor forum site called Simple Tractors which I use a lot for my Simplicity 2110 Landlord garden tractor.
got new power steering in MF-65. worked great, had to make extra trip to newark valley to pick up steering arm cause sleeve shaft was different. THANKS TO ALL FOR YOUR HELP.
sorry just saw this post, yes there are two diffrent steering arms for power vs manual. same pump/set up works on mf 50 and f40. i have converted a few, removed ps to put on manual to lighten front end for tractor pulls. parts manual for the tractors shows break down of both ps and manual. the gear box is also different config. but i didnt go that far,works fine either way.
(quoted from post at 19:23:48 01/22/14) sorry just saw this post, yes there are two diffrent steering arms for power vs manual. same pump/set up works on mf 50 and f40. i have converted a few, removed ps to put on manual to lighten front end for tractor pulls. parts manual for the tractors shows break down of both ps and manual. the gear box is also different config. but i didnt go that far,works fine either way.
willowbk, if you are still on here can you guide me in getting power steering for my dads MF50?? It has the gas motor if that makes a difference.
