Hello,
I'm near the end of finishing the rebuild on my 101 Jr RC (Single front wheel) and noticed that the rear wheels do not free-wheel by hand with the trans in neutral. Rear end is in the air...
Here's what I've done:
Replaced brake linings (pulled back off to verify it wasn't causing the issue, no help)
removed and reinstalled pto shaft and lift assemblies (to install the evil long bolt on the l/h brake housing for the transmission lube pump.)
removed and reinstalled shifter plate assembly
cleaned decades of gunk out of transmission, etc...
After reassembling (never noticed either way before, as I've had her on casters) the rear wheels don't spin in neutral, solid 'clunk', nothing soft like brakes). I've hand-cranked the motor, and neither rear wheel turns either direction. With it in gears 1-2-3-4-R the wheels turn as the should, or appear to turn as the should.
Any ideas? things to check for, etc...
Thanks in advance...
