Had a continental z134 gas engine from a 1961 MF35 rebuilt in an automotive machine shop and it will not start. It ran before but had low oil pressure and needed clutch work, so while I had it apart I had it rebuilt. It seems to be getting spark and the carb was also rebuilt and seems to be getting gas, but it will not fire over. After trying to start it I can pull out a spark plug and it is dry, no gas on it. Could it be the carb? Could it be the new cam? Has anyone heard of a cam being made wrong? I pulled off the valve cover and slowly turned the engine over and compared the valve movement with the lobes on the old cam and it looked right. I also towed it around the field a few times and it sounded like it was out of time, but the timing mark lines up with the number 1 plug wire and I have already switched the wires to see if it is 180 degrees out. I am stumped. Any suggestions?
