farmerscotty
well as luck would have it, I hooked the 489 haybine ( I know dark ages) on my 85 to cut some late wheat and grass hay. hooked up let it set and got on it today and my left wheel is stuck......pops and will move like 1 ft back and forth.......I loosened up brake and that didn't help. got it in the barn while sliding the left tire....it has popped once in a while, and I thought it was the brake if you backed up just a little it would release..........but not this time....
Any ideas........
figure it will be cheaper to just change out rear assembly than to fix it if I can find a dead mf 85 in SW Missouri.
thoughts since I know someone has some ideas?
thanks
no hay cut yet..........someday I have mf 285 to use instead of the 85 I just wanted to play with it............
417-838-6078
Any ideas........
thanks
417-838-6078
