Poor running Perkins
Forestl
New User
I have an old M F 20 industrial tractor with a Perkins 3 cyl. Gas engin. I have replaced the plugs,points,condenser,cap,coil,alternator, and had the carb rebuilt. The tractor starts great but backfires through the carb very badly. Misses out when put in gear. Are there any suggestions?
A lean condition will cause a backfire. A burnt valve will do the same. I would start with a compression test to eliminate that problem. All cylinders should be within 10% of each other.
Then check to see that your points are gapped properly and adjust if needed.
After that, start adjusting fuel mixrures.
I would bet on a lean condition or bad valve, but make sure you have a good solid spark at the plugs first.
