MF 50 rear tire rims and 16.9 tires
I have found a pair of 28 inch wheels off of something later model than a mf 50 these have the heavy cast centers in them, they are power adjust rims.......16.9 x 28 is
the size........
I know they are much heavier than the standard power adjust wheels on a mf 50......will they work.......???
here is wheel
as long as the center hole is the same or bigger and bolt pattern is the same they will bolt right on
I think they are same from what I see in the pic
The 50 has the small 8 bolt pattern, those in the photo are the large 8 bolt pattern so they won't bolt up to the 50, unless you find the small to large adapters I've seen on a 3600 Ford recently..
