Hi,
After accidently putting the hydraulics momentarily into Constant Pumping with no implement connected my Mf135 (1964) now has little power to the lift arms. It will lift me about threequarters of the way up. When under this load it leaks oil from the small grease nipple sized item, with the loose square metal cap, with three small indentations in it. This is sited to the front of the seat on the left hand side. At a guess I would say it was a breather but cannot find it in my manual.
I have taken both side panels off and cleaned the filter. There does not seem to be and oil leaking from the vertical pipe or dropping down from higher up. There is some turbulence to the left of the vertical pipe. Is this usual?
The lift arms lower when the engine is turned off.
Any suggestions would be greatly appreciated.
