MF65. Injector pump
Tequila
Anyone have knowledge of a good source for an injector pump for a AD4-203 diesel. Mine is full of sludge and think it's history. Nothing close
by here??
I've saved several pumps that were thought to be history. Does the rotor still turn in the hydraulic head, or is the rotor sheared in two? If the head is not broken the pump may be saved...
Thanks dieseltech, I hoped you would chime in. The rotor shaft turns properly, however in the side inspection window it looks like 3 cap screws, 16 point 3/8 heads. One bolt head had sheared off and was laying in the bottom of housing. I think those 3 bolts have to be removed to disassemble the pump. Am I correct on that, I have no exploded view to be sure.
