MF 265 Power Steering Pump Peak
Axtell
Location
RDU, NC
I have an MF 265 which I believe uses the Parker-Hannifin power steering pump. There appears to be a leak where the reservoir mounts to
the pump, but I really can't see for sure as the leak is on the engine side of the reservoir, but from the ground I cans see the leak streaming
down along where it mates together. My question is to whoever may be familiar with this pump, can the reservoir be removed without removing
the pump and are there any surprises if I do. It looks like there is an o-ring there that can be replaced.
Thanks,
I have a 180 and believe its the same set up. That reservoir can be removed with the pump on there. The filter is in there as well.
Thanks guys. It is an out of town Sunday repair needed for Monday and wanted to make sure I had all bases covered. Thanks for the tip on the filter.
It depends on the serial number of the tractor.
A 265 with serial number 9A284067 to 9A287064 used the Plessey pump.
1662566M1 (filter)
1887994M1 (tank o-ring)
1887988M1 (tank plug, fiber washer)
1887996M1 (washer, tank to stud)
A 265 with serial number prior to 9A284067, after serial number 9A287064, and 265's prior to serial number 9A349239 used the Parker-Hannifin pump.
1039660M1 (strainer)
367974X1 (o-ring, tank) (4 15/64" ID x 3/32")
831452M1 (o-ring, fill plug)
1020224M1 (seal, tank to bolt)
