farmerscotty
Ok I have acquired a mf 50 with 4200 hours on it.......has the 3 cylinder perkins in it......straight little tractor.
someone let the weep hole for the clutch area stop up, drained about a quart of oil out of it when I took off inspection plate and then cleaned the cotter key hole out.
it doesn't leak much on the low side of multipower but does leak more on the high side..will that be the sealing rings on the output shaft or is it simple like just one seal that you can get to without taking transmission apart.......I know I have to redo clutch since it is oil soaked.......
help!
help!
