I have an MF 265 which I believe uses the Parker-Hannifin power steering pump. There appears to be a leak where the reservoir mounts to
the pump, but I really can't see for sure as the leak is on the engine side of the reservoir, but from the ground I cans see the leak streaming
down along where it mates together. My question is to whoever may be familiar with this pump, can the reservoir be removed without removing
the pump and are there any surprises if I do. It looks like there is an o-ring there that can be replaced.
Thanks,
Thanks,
