Eric in Sonoma, Ca
When the F40 engine started the starter motor kept spinning.
When the key was turned off the starter motor kept spinning.
To stop the starter motor I had to disconnect the battery ground.
When the battery ground wire is touched to the battery terminal the starter motor engages.
What do you think the problem is?
Eric
Eric
