New to fixing tractors
New User
Hi All,
Just removed my steering cylinder pivot pin (note: not the pivot pin(s) in the axle) and put a new one in. Started turning the steering wheel to change the angle of the "arm" (upper steering arm)to give access to the bolt holes on the end of the steering cylinder so that I could put those bolts back in.
But instead of the usual resistance when turning the steering wheel, it spins freely, and the "arm" isn't moving out of the way. Is that because I don't have the bolts in? Or did I just break something?
Thanks in advance for all of your help!
