mf 203 power steering valve
mark18
i have a mf 203 ser jnf659001536. the power steering valve is leaking bad out the top of valve. i have the parts and service manuals. but am not sure i am heading in the right direction. first can i service this valve to fix the leak. second can i remove the valve without removing the steering shaft
power steering leak. replaced seal and o ring on tube above valve with parts from mcmaster carr leak fixed.
