MF 65 wheel centers
Ed M
My adjustable wheels are rotted through around the valve stems.Can I use my centers for non adjustable outer rings or do I need to buy new centers also ? Thanks
My son got a 65 free "Was running when Parked". One rim was rotted out around the valve stem but other wise OK. We cut out the bad area and made a patch. Welded it on the outside and used the wire welder to fill the inside and ground that down to smooth. Then drilled a new valve stem hole. Not the prettiest but it works fine and much cheaper than a new rim.
