Dopp Creek
My 1963 65 diesel has a MF99 loader mounted on it. There is a plate with three countersunk capscrews secured to the front pulley and that plate has a long 3/4" shaft brazed to it. That shaft is machined for a woodruff key and it enters but does not completely pass through an 1.62" hole on the front axle. As the tractor is idling the end of the shaft inside that 1.62" hole has quite an orbit to it, maybe .25". I'm trying to find a pump coupler that would accomodate the shaft runout but everything I've found has a massive OD that won't fit inside that 1.62" hole. What do your tractors have for a coupler? Any suggestions on how to solve is? I don't know what the original Massey set up would have been. Haying season is getting closer so I need to get this figured out .
Thanks. Tim
Thanks. Tim
