180 steering column
If that is the needle bearing that goes in the steering column they are expensive and only available from MF. Last time I needed a set was 3 or 4 years ago and they were almost $100 each. I had mine bored out and fitted with long bronze bushings and a grease fitting. Used a piece of grease gun hose to get the fitting out were it was easy to get at to grease . Worked great. On mine there was no grease fitting on the original.
That's what I'm finding out. I got one old stock bearing for $30 and couldn't get a second one. I ended up making my own bushing from some stainless milk line. Its not perfect but its a whole lot better than it was.
The shaft was already pretty tore up from po running it with nothing in there. If I did get both bearings I would've had to build the shaft up.
