MF65. Injector pump
Tequila
Ran fine before storing for the winter. Bleeding system I got good fuel pressure to both bleed ports on the pump, but zero fuel to the injector
lines. AD4-203 Perkins, CAV Inj. Pump. Anyone got any ideas I may be missing.??? Looking for a reliable pump shop for rebuild. None in my
area( SW Utah) would appreciate any recommendations there as well????
ok make sure your "pull to stop rod" has not come out of the little spot under the cover on top of the pump.
I had that happen once. Just pull the top cover off of the pump and make sure it is in the hole where it is suppose to be.
warm up with wood heat
