MF 65 gauge set....has anyone tried these?
I was unable to see what you were referring to . I got a set for a 165 from India on ebay so cheap I didn't know if they would be any good. I
used all but the fuel guage (did't need) and was very pleased.
(quoted from post at 21:02:19 04/27/15) I was unable to see what you were referring to . I got a set for a 165 from India on ebay so cheap I didn't know if they would be any good. I
I wondered whether it could be seen, since when I pulled it up it was just what I had viewed. Anyways, thanks for the input, it sounds like the ones I have been looking at will work fine. They really look nice and can't beat $30.
Thanks again!
(quoted from post at 11:47:12 04/28/15) No tachometer with this set.
Nope, not with that set, but another for fourth something has the tach. Thanks for the previous poster putting up the correct link.
These gauges should work fine. As you stated your rpm gauge (tachometer) is working as well as your oil pressure gauge. You may or may not need the fuel gauge depending if your tractor currently has one. If you have a fuel gauge that isn't working the problem may be with the sending unit in the top of the tank instead of the gauge.
(quoted from post at 02:23:04 04/29/15) These gauges should work fine. As you stated your rpm gauge (tachometer) is working as well as your oil pressure gauge. You may or may not need the fuel gauge depending if your tractor currently has one. If you have a fuel gauge that isn't working the problem may be with the sending unit in the top of the tank instead of the gauge.
Is there a simple method in troubleshooting it to determine if the gauge or sending unit is bad?
I bought a set from harbor freight I think it was $20. oil, water and amps, I intended to use them on my TO 20 yet I haven't gotten around to it, they should work fine as well and another option to consider
(quoted from post at 06:19:15 05/01/15)
I've never been to harbor freight, guys at work go often. I suppose I need to get out more. Currently I'm changing out the worn front hubs/bearings. Possibly the next thing will be gauges. Thanks for all the input.
