Battery Charge M-H 30
indy bob
I have restored a 1949 M-H 30. Had generator re- built new cut out, new 3 position switch, new wiring harness. when the battery wire is connected to the positive post of the amp meter it displays battery charge to the negative. I switched the wiring on the amp meter it now shows charge to the positive. when the switch is pulled to the light position and maximum charge the amp gauge shows 10 amp discharge. Any help is appreciated.
Battery connected, engine not running, with switch turned on ammeter should swing to negative. Start engine and with generator charging ammeter should swing positive.
