MF 135 Ring gear and pinion
Hello,
I am trying to help a friend locate parts for his 1972 MF135. He is looking for a new/new-old stock 37 tooth ring gear and a 6 tooth pinion. If anyone can point me to a supplier it would be greatly appreciated.
Thanks!
I have a new ring gear and pinion I bought years ago for a 1973 135 but never used but not sure of the ratio. If you are interested I will try to get it out and check the ratio.
Mr. Tibbetts,
If you would, please check on that gear and pinion. Once you look at it, please email me the info of what it is and a contact number where he can talk to you personally. My email should be open.
Thanks again, your help is greatly appreciated.
There is a good size tractor salvage yard here in southern Idaho. It's called Burley tractor salvage. If Mr. Tibbetts is unable to help you might give them a holler. Maybe freight would make it unfeasible, Don't know where your located. Phone # is 208-438-5420.
Thanks for the info. We are in NC so it may cost a bit to ship. I will pass the name and number along. Thanks again
