My 1105 has a weak 3pt lift
Steering is working fine starts working as soon as you crank it don't have to rev the engine to get it steering
Remote hydraulics work great
This winter I put in a rebuilt radial pump because mine started to leak at the seal and then went ahead and replaced the pump
But any how the lift goes up and it'll pick up a couple hundred pounds but that's it
When the lift is in transport position the steering get stiff still turns just have to really crank on it
This is the first time I've used the lift mostly pull my chopper and mower with this tractor
But I bought a big tiller to use this year and now I can't get the lift to pick it up
Is this signs the pump under the floor board needs attention or something else
Thanks
Thanks
