tluchterhandt
I just purchased a Massey Ferguson 65 diesel tractor. I've been pulling some maintenance on it like oil change, lube, and air filter. What I found in the pre-cleaner assembly instead of the common course steel mesh, was steel wool packed into the canister. I attempted to open the canister to remove it and I can't see how it comes apart. Does it come apart? It's kind of dinged up around the edges like someone has attempted to pry it open. I did manage to pull it all out thru the pie shaped holes.
How do I replace the steel pre filter mesh, and where is it available? I'm sure I will have more questions on various topics as I work thru thus tractor. I did download a copy of the original Owners manual. The serial number is 680404. I haven't been able to locate the engine serial number, really can't find the area on the engine that the manual shoes of the location.
Any help/advice would be greatly appreciated.
