Morning: I wonder if anyone here has some info on the 1010 front electric clutch?
I am wondering what normal current draw is? and possibly the "ohms" resistance of the clutch, from
power wire to battery negative post.
This unit is generating excessive!! heat, within 2 or 3 minutes of being turned on, mower deck is free turning, lifted
off the ground position, or on the ground is the same result.
Thinking slightly shorted clutch coil? worn clutch pad(s)?
Research before taking things apart.
TKS
TKS
