I have a 165 with multipower which is stuck in low. Is there anyway to lock the multipower in high? The tractor has to be split to install a new ring gear. While it's apart, if the multipower can be locked in high, that would be the time to do it.
Also, about the same time the multipower locked itself in low, the independent PTO lost its power. The shaft turns when the engine is running but it won't power my bushhog.
From what I've read on YTMag, fixing multipower is real expensive...locking it in high would be fine for my purposes.
Thanks
Thanks
