gary in neb.
354 perkins starts hard after it sets a day or two. the motor is in a combine but my question is on the pump system. the filter system is marked 1, 2, 3, 4 on the filter housing. the line that comes off the lower part of the pump went to the "out" side of the filter housing closest to the pump (sorry don't remember the number. my old system went to the "in" so that's how I set it up. seems to me it's bleeding off just a bit. little snort of juice and it goes and runs fine. I have not put the line back to how it was as of yet. it's a CAV pump and I was thinking that line was lube line so should flow back to the filters "inlet" side not "outlet" but I could be wrong. it's happened before.
thoughts?
Gary
thoughts?
Gary
