add remote for a mf65
Rkh
Can i add a remote that attaches next to the shifter to my mf65 gas & do i need to put something under this remote like a pump to operate the remotes? Does this type slow to run a
front 5' bucket?
this is what i'm talking about. My tractor doesnt have this-stole this from another forum.
One of those valves will bolt right on. You need to use the tube from the cover that is on there now. You could also put a diverter valve on there and then outlets.
As Brendan said, you can add one on that runs off the internal pump with little difficulty. But speaking from experience, you will find it very slow for a loader (I think the pump rate of these new was just over 4 gpm). If your main goal is to run a loader, you would be better off mounting an independent front pump system. I did this on mine, and the difference was huge compared to when I ran the loader off the remote from the internal pump.
