Working on a MF275 that has a leak in the rubber part of one of the power steering hard lines. It's the one that connects to the upper part of the P/S pump and then twists its way underneath the hydraulic motor (where the cracked rubber portion is) that the steering wheel connects to and then into the hydraulic motor itself. Is this a low-pressure line that can be patched or must it be entirely replaced? I cannot find a part number for it.
Anyone know how to replace it? It has a lot of turns and twists in it and I'm not even sure how to replace it short of cutting the old one into several pieces to remove it.
