MASSEY HARVESTER
I have a 255 and i think the draft control is broken. when using a chisel plow or a subsoiler I tried to
make it work but I get no response out of it with the lever in any position. I have to use the position
control constantly when i hit a hard spot.
It has never worked on this tractor but from my understanding when adjusted it should lift the 3 point when
you hit a hard spot or it digs too deep. again it makes no difference where the lever is and the 3 point
will only lift if i lift it slightly with the position control
any ideas what the problem could be?
