weight of rear tire wheel with calcium
These are the old tire size numbers so you will have to figure it out for the new numbers. 10-28 which is not the 11.2 will be around 310lbs and the 11-28 which is the 12.4-28 will be around 440lbs. Ad the 12-28 which should b the 13.6-28 will be around 504lbs. This is all right out of a Ford NAA manual and a Ford 801 manual owners that is. That is only the weight of the fluid it self not the tire and rim so you have to figure it form here
Any one of these will kill you if they fall on you. I spent a few years in the commercial tire business and heard of a tire dealer being crushed by a falling tire. Everyone be careful removing and working with these heavy assemblies.
