mf65 gas differential lock
As you are sitting on the tractor, it is a pedal just to the rear of your right foot. It might have the pedal part flipped up out of the way. BT
As you set on the tractor your right heel should contact a rod / pedal. If not all you have there is dipstick. Do you follow? If not I can get some pics.
65 diesel had it before the gas models did, if it's there will be a bent rod to push down with the right heel. 165 models had the flip up pedal instead of the rod.
Heres a picture
