MF 135 help please
DDzhere
New User
Hello all newbie here! Just bought a Massey Ferguson 135 Serial # SGM641009747. My issue is I need a new steering shaft and nut. Mine is 21 1/4" long the ones I'm seeing for manual steering which mine is are 21 3/4" any help on this would be appreciated. I'm not sure what I need to order considering my serial # falls into the range for the 21 3/4" shaft.
Thanks!
For no power steering it can only be part number 180538M91 (21 1/2" long).
For power steering part number 1751666M91 (21 3/8" long, Deluxe, and Vineyard)
All the other ones (manual, and power steering) are longer.
(quoted from post at 18:09:45 03/22/15) For no power steering it can only be part number 180538M91 (21 1/2" long).
Thanks! The upper and lower bearings were destroyed and ended up in the bottom bearing cup and chewed the bottom of the shaft off. Makes sense it could have eaten 1/4" off. Would you happen to know the bearing part #'s are? I cant seem to find a parts break down for the 135 online. Thanks for your help!!!!
180549M1 Bearing Lower (need 2 of these)
180548M1 Retainer, Lower Bearing
180526M1 Cup, Bearing (need 2 of these)
180528M91 Bearing Assembly, Upper
180563M1 Seat, Bearing Retaining Spring, Upper
180572M1 Spring, Bearing Retaining, Upper
180573M1 Seal, Dust (13/16 x 1-9/16 x 3/32" Felt)
510849M1 Cap, Steering Column (Plastic, 4-1/16" Long)
195592M1 Nut (13/16" NF, Hex.)
If you are in North America you can log on as guest user for AGCO online parts here http://www.agcopartsbooks.com/PartsBooksN/login.aspx?region=NorthAmerica
