M-H 30 ring gear
old
So is the ring gear in the M-H 30 replaceable?? If yes where does one find such a ring gear. Looked in the parts area of this site and did not find it listed.
Thanks
You can take it off and turn it over it is just bad on one side. Heat it a little and they go back on fairly easy. If you need a new one call Lemmons Tractor Service at 765 938 1808. They should be able to fix you up.
Tom
I know this. My sort of local Acgo dealer could not find the ring gear listed.
The M-H 101 Jr, 102 Jr, Colt (21), Mustang (23), (Mustang), 20, 22, 30, 81, 82 should use the same ring gear.
Ring gear should be part number 32654A (103 Teeth, 12-1/8" ID, 13-1/8" OD)
the correct name for the diff. gear is called the "crown gear". referred to crown and pinion, and the are sold as a set not one or the other.
