Hello!
We need some input please. We have a MF 65 that needs the right tie rod replaced. However -
The part that we removed from the tractor does not match any of the parts we're finding for this model. The serial number on our tractor is SGM654732.
The rod that we removed is about 16" from the center of the loop to the end of the rod. The rod diameter is .74". The rod itself is a notched rod. We will replace the entire assembly if needed.
It's been suggested that this is not the original tie rod and may have been replaced anytime in the last 50 years. We've only owned it for a couple of years.
SO -what part do we order to fix our tractor?
Thank you so much!
Thank you so much!
