MH44 versus MH30 Rearend...?
Goldsburg
What are the main differences between a MH30 and a MH44 rear end?
What would be the approximate weight difference?
Thanks,
Goldsburg
Not sure if really any weight difference, gearing is changed a bit on 44 4 cyl though. 30 and 44-6 are geared the same, 1500-540 pto while 44-4 is 1350-540. Ground speeds are changed also.
I believe the axles are the same for 44,33 and 30 with there being 3 styles, standard, rowcrop and rice. I know the gearing is different. There are 3 styles of axle housings, Standard, Row Crop and Rice with the Standard housings being the shortest and lightest. The rice configuration may have only been on the 44's.
