hydraulic controls on a 65
Brendon Warren
I'm putting outlets on my 65 diesel. So does the one on the right give me 4 outlets with two way cylinders? And the one on the left give me two outlets with one way cylinder? I have no need for four outlets but two way would be nice.
From your picture hard to tell if they are one way controls or 2 way. Most I have seen are 2 way but can be used as one way
My masseys have the control like you have on the right. It gives me slow 2 way on the right if the left handle is locked back
in constant pumping .
The valve on the left is a single action valve. The right hand port is for a remote cylinder by itself. The left port operates a remote cylinder in conjunction with the 3ph. The other valve is for dual action, but the left ports still operate the remote cylinder with the 3ph. There was another style valve that a 3rd. spool could be added to on the right side. It would operate 2 remotes without affecting the 3ph.
Look for a screw under each spool on the right valve in photo. Looks like what was on 165, 175, and 180s. If the screw is there it's for shifting the valve for single or double action, if I remember right turn full in for double, and full out for single action cylinder.
