This message is a reply to an archived post by SaveMy50 on September 03, 2014 at 13:12:29.
The original subject was "MF 50 Clutch Not Engaging".
Attached picture of what I found on top of the inspection plate, still don’t know where it comes from after splitting tractor. Lost one adjusting screw. See I have to replace the clutch cover (cracked and housing broken for release lever), likely the whole assembly I suspect. Do I have to worry about marking the clutch and flywheel if I replace whole assembly? Do I need the T bolts? The release bearing appears to be ok, but will likely replace as well.
