I have a MF40 industrial with a Perkins 3 cylinder gas engine.I can not find the serial number on the engine.It is not next to the engine block on the upper left side next to the water outlet.Any suggestions on where to look.
I am also trying to get the head off.I have removed 18 head bolt nuts and the water hoses.I did not remove the exhaust or intake manifold.I am trying to lift it from opposite corners with an engine hoist but it will not come off.Do I need to remove the manifolds? Any other suggestions?
