Hyd pump Do I need to pull the PTO on 30 ind
Yes. IIRC, take plate with 4 bolts surrounding PTO shaft at rear off, then pull it out. Then pump slides back a bit off front part of shaft and lift it up and out. MK
Thanks. Thats what I figured but wasn't sure. New to Massey? I'm mostly Case tractors. I ordered a used original service book but it's not here yet. Hopefully I can find out why the three point does not work at all. Dick
