How do I remove the hydraulic pumo on my FM30 ind?
I have the top cover off. It looks like the bar with the roller that that pins to the pump might have lost the pin? I want to remove the pump. I removed the coupler on the top shaft and removed that shaft. I took the side pins out of the housing that hold the pump in place and it looks like there is a coupler on the shaft in front of the pump? I removed that cotter pin but I can't seem to get the pump out? Any ideas?? Thanks
