? On Massey 44 Oil and Gas Line Fittings
Scott(IN)
Massey uses a rubber gasket at the connection of oil line fittings and I was wondering is this something you can get at an auto parts store. The massey part # is 29760. I figured this is something common but I have never seen it used elsewhere.
oliver and cockshutt use them also on their gas fuel lines. I get mine right from the dealer.
IH model 100 injection pumps used 3/8 inch grommets for the fuel lines, and 5/16 or 1/4 inch for the oil line, don't remember which size. MF diesel pumps used 1/4 on 3 and 4 cylinder injection pumps while 6 cylinder pumps used 5/16, gives you more sources..
Check at your local diesel fuel injection repair shop. That's where I get mine. Like the other guy said, there's at least 3 common sizes.
