hotrod3000
Took my father's 135 into the massey ferguson dealer to have some fuel leaks fixed. They called and said that the injector pump needed rebuilding and that they would have to send it off for repairs. keep in mind that the tractor ran great before it went into the shop. It crank great. Snow could be up to the top of the exhaust pipe and all you needed to do was bump the starter. Great power etc. Theyou called back 2 days later and said that the pump was warn past repair and needed replacement. I went to pick the tractor up and noticed that it did not sound the same cranking. After driving it around the dealer it began blue smoking and lost power. The mechanic worked on it for a few minutes and bleed the pump And had it running good.
Took it home and the next cold day we tried to crank it we had to crank and crank the engine to get it to run. Also when you have it above idle and bring it back to an idle it Stumbles before going into an idle. The new pump says built in Romania. I am kinda scared of that. Can anyone point me in some kind of direction with this issue. Thanks.
