Mf-65 PS leak
Rkh
have a power steering leak around the shaft end of cylinder. can you still get seals to repair?
heres picture
I think I had to pay around 70 bucks for the kit which has about 10 cents worth of rubber seals but unless you can pull out the old and match at a hardware store then its pay up. Not a hard job but make sure the rod isn't rough or losing the chrome, you don't won't to know the price of that rod from agco!
I have a Barnes pump 184-856-m91. the agco book shows only bruning & Benton pumps. can i use these parts or am I doing something wrong?
I did a complete rebuild 7 years ago with the Agco kit. It had all the parts for all of the different style pumps (I had the same pump you did-kit number 830 860 M92). It had all seals I needed do redo the cylinders. About a 4 hours job including removal and reinstall and cleaning. Hasn't leaked since. I did need some help from this site in order to do disassemble pump since the repair manual had it all wrong. Let me know if you need any assistance.
I think agco has the cyl. listed by serial # of tractor, yours looks like the early stile by looking at the hoses but check your serial number.
