Massey 85 hydraulic/lift pump.
72455gsx
New User
Hello, I am new to Yesterday`s Tractors. I am working on a Massey 85, gas engine, 8 speed trans, with a loader. The hydraulic/lift pump is all scored up.
I have done a bunch of searching on line for a pump but cant find one for the 85. Does anyone on here know where to get one or maybe a rebuild kit?
Hello
Which 85 tractor do you have there are two different hydraulic pumps.
one for the western style and the other for standard and high arch.
I believe that one hydraulic pump is for the 85s with the hydraulic lift(3point hitch) Maybe someone on here can clarify that?
Anyway I may be able to help with a pump or parts, if we can figure out which pump you need?
Wayne
It is a 85 standard with 3 point. tractor data says the western were called 88`s. I don't know much about Massey tractors. I am in Wisconsin by the way.
My hydraulic pumps will be for the 85 with no hydraulic lift. So I probably cant help there.
What parts would you need to repair yours? Go to Agco parts books online...they have an exploded picture of the pumps. You may be able to get the new parts from an Agco dealer.
AGCO parts book shows only one pump for the 85 standard and hi crop. 183834M91. No mention of 3 point or not. The 88 western has a different pump.
Yes that is right. I missed that.
Can you give me the part numbers of the parts you need? We may have a hyd pump here that we can get the parts you need, but I need the part number from you.
Wayne
There is a salvage yard that has a pump but still in the tractor. If it turns out that pump is bad also then we might just get the parts from you to fix the pump we have. I know the pistons and the bores are junk but have not looked at anything else in the pump yet, so I don't know what else it may need. I will let you know.
We finally got a used pump and got all the stuff to fix the fried PTO clutch. Everything works now. :D
