Ferguson 1080 3pt lift problems
I have been having lift problems for several months and have pulled all my hair out on it. It lifts, up and down, It will hold my 260lb body up, but when I let the left down it want lift me back up, want even try, step off and the arms go up. all this started when I pulled the left plate, (top plate) off to fix the slip coupler problem. And my pto shaft turns all the time now. I cant find any local mechanic that will work on it so I am really am relying on some help from yall to get me back going. Thanks
Can you tell me how I will know, I am getting ready to pull it back apart this week and want as much information as I can get for when I do. Thanks
When you pulled the top cover did you remove the round cover on the right hand side with the dip stick for checking the fluid before you took the top cover off?
